Unique Drop downs in form
Thread began 12/08/2011 11:39 am by Brad Lawryk | Last modified 12/09/2011 8:20 am by Brad Lawryk | 697 views | 2 replies |
Brad Lawryk
Hi guys,
I have a form that consists of two identical drop menus. I need users to be able to select from both, but before the form is submitted I need to check that the same value wasn't selected in both.
IS there a way to do this?
you would need to hand code javascript to accomplish this.
assuming the name of the form is "form" and the name of the select lists are "select1" and "select2", the javascript function would look like this:
function checkform(form) {
retval = true;
if(document.form.select1.value == document.form.select2.value) {
alert("please make unique selections");
retval = false;
return retval;
</script>
then add an onsubmit call to the form tag:
<form id="form" name="form" method="post" action="" onsubmit="return checkform(this);">
Brad Lawryk
Ah! Thanks JAson, I was looking at ways to do it with triggers if there was one. I guess I was looking at the wrong method.
I appreciate your above and beyond support by supplying that code.
Thanks!
