PG v2 Confict with Jquery
Thread began 12/07/2011 1:04 pm by anonymous | Last modified 1/12/2012 1:27 pm by rikaG_510 | 2380 views | 6 replies |
anonymous
Seems like this should have been fixed with version 2, but the PG v2 breaks all of the jquery on the page. I searched the forum and found a post that stated this was fixed in v2.
Please let me know what I need to do to get this to work on pages with Jquery.I need this done quickly, but really don't want to open a paid ticket for something that should work out of the box.
Thanks,
Tony
rikaG_510
I am having a similar problem.
I have a jQuery/css based vertical slide menu, and haveing PowerGallery seems somehow to force all the menu "kept unfolded", where only opened category area menu should be unfolded.
(See: shop_160_covers.php )
I tested with jQuery LightBox (similar effect with PowerGallery, but much simpler) to see if that triggers the same symptom, but it didn't.
(See: shop_054_adptv_test2.php)
I'd like to stick with PowerGallery, as it is easy to use, and it gives me sliding effect that I can not hand-code.
Could you take a look and advice me what to do to keep the menu folded?
Thank you for your help in advance.
Rika
it's probably a conflict with the version of jquery being used.
in the /powergallery/galleries/ribbon_lightbox_swift/index.php file, remove the following line:
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.4/jquery.min.js"></script>
rikaG_510
Hi Jason,
Thank you for your reply, I did what you suggested.
The menu is back to what it's supposed to look like, but this time the gallery's effect is gone.
When I click images, it just jumps to another page with a image.
What would be the next move?
Rika
rikaG_510
Hi Jason,
This is just to let other people know just in case.
1. I deleted the code from index.php as you suggested.
2. On my php file that I have a powergallery and other jQuery stuff applied, I switched the jQuery library code to the one I deleted from index.php, from the one I had before.
And everything is working perfectly.
I guess other jQuery stuff I had could work with by PowerGallery's jQuery version, so this worked out.
Thank you again for your help, finding out the root problem was the jQuery's version difference was a big hint for me.
Rika ;-)
