Unable to enter line breaks in infowindowtext
Thread began 12/06/2011 5:01 pm by info170926 | Last modified 7/19/2012 2:04 am by Miguel | 1222 views | 7 replies |
info170926
How can I add line breaks to the following code in wagmp_map_1.asp file
infowindowtext: 'Text Goes Here',
This would work fine but the map does not load if the text has a line break.
Goes Here',
Do we need to change this to infowindowhtml and if yes how would we go about it?
use br tags:
infowindowtext: 'Text <br />Goes <br />Here',
info170926
Thanks for your revert.
The example I gave you is just a situation that would be loaded from the recordset. We have a back end where user can enter the description in a text editor (HTML Supported code is created) and this description shows up in the infowindow.
Now, if the user enters
hi how are (return)
you today
the text editor generates the following code
hi how are <br />
you today
he gets an error since the code goes to line 2 after <br/>
What can I do to make sure that a return does not cause this
you could use the replace function to cnvert the line break vbCrLF to a blank space:
Replace(string, vbCrLf, " ")
if you need help implementing this, send a copy of the wagmp_map_1.asp page
info170926
I have attached the file for you.
wagmp_map_1.txt
ok, so the code for the info window is:
infowindowtext: '<div style="width:225px; height: auto;"><span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><%=Replace(Cstr("<strong>" & cStr((maps.Fields.Item("name").Value)) & "<br /></strong><br />" & cStr((maps.Fields.Item("description").Value)) & ""), "'", "\'")%></span></div>',
change that to:
infowindowtext: '<div style="width:225px; height: auto;"><span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><%=Replace(Cstr("<strong>" & cStr((Replace(maps.Fields.Item("name").Value, vbCrLf, " "))) & "<br /></strong><br />" & cStr((Replace(maps.Fields.Item("description").Value, vbCrLf, " "))) & ""), "'", "\'")%></span></div>',
Miguel
I got the same problem but with php how can i resolve this i tried
str_replace(array('\r\n', '\n', '\r', '\t'), ' ',($row_contacts['cAddress']))
With no luck dont know what else to do also i added the strip_tags and nothing i just get the java error
Miguel
Got it done on php for some one else using an address from the htmleditor i added to the page that has the map this function
function replace_line_breaks($str, $replace = '') {
    $chars = array("
", "\n", "\r", "chr(13)",  "\t", "\0", "\x0B");
    return str_replace($chars, $replace, $str);
then on the google map wizard interface where we add the custom info bubble i placed
<?php echo replace_line_breaks($row_contacts['cAddress']); ?>
works like a charm now.
I did this cause the maps are been loaded dynamically from coordinates, and on the contact page i have a small text box with the htmleditor so the user can place their address formatted instead of having another text field to fill i wanted to reuse that field this solution hope helps other users of our comunity
Miguel
