Tweaking search criteria - AND/OR etc
Thread began 12/04/2011 9:59 am by iainmacdonald331081 | Last modified 12/05/2011 1:11 pm by iainmacdonald331081 | 739 views | 4 replies |
iainmacdonald331081
I've got a working search page here, for a driving schools database:
search/
But I'm not sure how to quite get the search as I would ideally like.
Basically there are a number of text fields, all using AND, which is fine.
There are also two checkboxes for schools with female instructors or intensive course.
So for example, I have added two schools with a name containing Handprint.
The way I have in my head it would work is that if you just search for Handprint, and leave both checkboxes unchecked, it should find both schools called Handprint.
i.e. WHERE school contains Handprint AND Female = Y OR N AND Intensive = Y OR N
But using AND, if they're left unchecked its only finding the Handprint without them checked.
WHERE School contains Handprint AND Female =N and Intensive =N
//comparison list additions
$WADbSearch1->addComparisonFromEdit("School","S_School","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("Owner","S_Owner","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("Area","S_Area","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("Town","S_Town","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("County","S_County","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("PostCode","S_PostCode","AND","Includes",0);
$WADbSearch1->addComparisonFromCheck("Female","S_Female","N","N","AND","<>","=",0);
$WADbSearch1->addComparisonFromCheck("Intensive","S_Intensive","N","N","AND","<>","=",0);
Alternatively, if I use OR for the checkboxes, the results return and school called Handprint, or with no female instructors or intensive courses.
WHERE School contains Handprint OR Female = N OR Intensive = N
$WADbSearch1->addComparisonFromCheck("Female","S_Female","N","N","OR","<>","=",0);
$WADbSearch1->addComparisonFromCheck("Intensive","S_Intensive","N","N","OR","<>","=",0);
Not sure if I've explained that very well, or if its even possible?
Thanks for any pointers or suggestions.
set the checked value of the checkboxes to "Y"
in the data assist search wizard, don't use the checkbox comparison type for those 2, use the edit comparison type.
this will cause the checkboxes to be ignored if not checked, and use Y as the comparison value if they are checked.
iainmacdonald331081
Thanks Jason.
The form in the page above was done with the full WADA wizard.
Just tried using the search wizard, and not sure where I'm supposed to be selecting any comparison type though....
I've got the 'Select the search element to add' page, so assume I select 'Single Checkbox' plus AND or OR.
Then the Checkbox Search page, where I select the column (e.g. Female), Column type - just text? Checked value = Y, and unchecked value <> Y.
But nothing about checkbox or edit comparison type.
And the results page it created doesn't look like its doing anything - it hasn't created anything at all within the BODY tag.
Not sure what I'm not seeing here...
And similarly, in the main WADA wizard, I can only see where to select AND or OR, and how its displayed, eg a Checkbox, and the criteria, e.g. =, <>, contains, begins with etc
I'm not talking about using the wizard to recreate the search. instead. on the results page, open the server behaviors panel (Window -> Server Behaviors). Double click the Data Assist Search server behavior to edit it.
select the criteria for the first check box and click the edit button. Change the Criteria Type from checkbox to edit.
Repeat for the second checkbox.
on the search page, select the checkboxes, in the property inspector, set the checked value to Y
iainmacdonald331081
Thanks Jason - that all looks like its doing exactly what I want now.
