messed up activation code.
I tried to update the admin area just by changing the pixel width and it screwed up my activation code. Please help!
please provide more details. What do you mean by "screwed up my activation code"?
do you mean you are now getting an error about the activation code?
If so what is the error?
without knowing in what way the activation is "screwed up", i do not have enough information to answer the question.
sorry about being unclear. When I did this: showthread.php?p=114940#post114940
I tried to change the amount of pixels so I could add more space. (instead of waiting to hear from you)
That was on the admin page product_update.php page.
When I did that, I got this error on the products update page:
Fatal error: Cannot redeclare WA_AuthenticateUser() (previously declared in /var/www/vhosts/enhancedhealing.com/httpdocs/WA_SecurityAssist/Helper_PHP.php:10) in /var/www/vhosts/enhancedhealing.com/httpdocs/webassist/security_assist/helper_php.php on line 58
Then The serial number for the site settings is saying (screen shot)
So what I see on the the product_update.php page is this below. I don't see that the security line on there twice.
<?php require_once('../webassist/themes/theme_open.php');
$WAIncludeContent = new WA_Include(__FILE__);
<?php require_once('../Connections/PowerStoreConnection.php'); ?>
<?php require_once("../webassist/ckeditor/ckeditor.php"); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("../webassist/form_validations/wavt_scripts_php.php"); ?>
<?php require_once("../webassist/form_validations/wavt_validatedform_php.php"); ?>
<?php require_once("../webassist/file_manipulation/helperphp.php"); ?>
<?php require_once( "../webassist/security_assist/helper_php.php" ); ?>
<?php require_once( "common/properties.php" ); ?>
if (!WA_Auth_RulePasses("Administrator")){
WA_Auth_RestrictAccess("index.php");
change this line:
<?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
