onclick blocked?
Thread began 11/30/2011 3:24 pm by Steve | Last modified 11/30/2011 4:20 pm by Steve | 980 views | 3 replies |
Steve
onclick blocked?
I have an onclick event that does the basic open new window event but it does not work in the CSS Menu environment. onMouseOver works in the same environment...
The function is present and I can not see why it would not work...
live page: branding.php
$WA_localRoot
$WA_remoteRoot "/";
$WA_curURL strtolower((isset($_SERVER["PHP_SELF"]))?$_SERVER["PHP_SELF"]:"");
$assumedRoot $WA_remoteRoot;
if (
strpos($WA_curURL,strtolower($WA_localRoot)) === && (strlen($WA_localRoot) >= strlen($WA_remoteRoot) || strpos($WA_curURL,strtolower($WA_localRoot)) === 0)) {
$assumedRoot $WA_localRoot;
$WA_thisFile $_SERVER['PHP_SELF'];
if (
strpos(strtolower($WA_thisFile), strtolower($assumedRoot)) === 0) {
$WA_thisFile substr($WA_thisFilestrlen($assumedRoot));
else {
$WA_thisFile substr($WA_thisFile1);
$WA_ddsArray explode("/"$WA_thisFile);
$WA_dotDotSlash "";
for (
$n=0$n<sizeof($WA_ddsArray)-1$n++) {
$WA_dotDotSlash .= "../";
<ul class="level-0" id="cssmw">
  <li><a href="<?php echo($assumedRoot); ?>index.php">Home</a></li>
  <li class="parent"><a href="#">Our Phones</a>
    <ul class="level-1">
      <?php do { ?>
      <li><a href="<?php echo($assumedRoot); ?>product.php?prodId=<?php echo $row_rs_products['id']; ?>"><?php echo $row_rs_products['productname']; ?></a></li>
      <?php } while ($row_rs_products mysql_fetch_assoc($rs_products)); ?>
    </ul>
  </li>
  <li><a href="#" onclick="MM_openBrWindow('fastTrac.php','RPF','width=662,height=668')">Rapid Product Selector</a></li>
  <li><a href="<?php echo($assumedRoot); ?>branding.php">Custom Branding</a></li>
  <li><a href="<?php echo($assumedRoot); ?>order.php">Order Phones</a></li>
  <li><a href="<?php echo($assumedRoot); ?>newsletter.php">Newsletter</a></li>
  <li><a href="<?php echo($assumedRoot); ?>fcc.php">FCC</a></li>
  <li><a href="<?php echo($assumedRoot); ?>dealerLogin.php">Dealer Login</a></li>
</ul>
<script type="text/javascript">if(window.attachEvent) { window.attachEvent("onload", function() { cssmw.intializeMenu('cssmw',{select_current: 0, orientation: 1}); }); } else if(window.addEventListener) { window.addEventListener("load", function() { cssmw.intializeMenu('cssmw',{select_current: 0, orientation: 1}); }, true); }</script>
testing you page in FireFox, the window opens fine, it is a problem in Chrome and Safari. These 2 browsers have built in popup blockers that will prevent the onClick event from firing the window.open method.
see this post at stack overflow for more details:
open-new-window-after-a-click-event-not-working-in-safari-chrome
Steve
in menu.js I commented this line and now it works....
// aTags[a].onclick = this.a_click;
if (li) {
                                aTags[a].onfocus = this.a_focus;
                                aTags[a].onblur = this.a_blur;
                                // set up onkeypress events as well if orientation is known
                                if (this.orientation) {
                                    aTags[a].onkeypress = this.a_onkeypress;
                                    aTags[a].onkeyup = this.a_onkeyup;
Steve
Jason,
My tests were with FireFox (Mac) and EI8 (PC) neither worked but with the commented code it works fine now....
