Upload file renaming issue
Thread began 11/29/2011 12:13 pm by Brad Lawryk | Last modified 11/29/2011 3:00 pm by Jason Byrnes | 394 views | 1 replies |
Brad Lawryk
Hi guys I have the file uploading working great. But when uploading a second file with the same name it should rename the file with an incrément vale (which it does) but it doesn't upload the proper renamed value to the database. It retains the original file name in the database.
in the data assist Insert record behavior, make sure you are binding the image column to the WA Uploaded Files (File Field Name) -> Server File Name.
this binding is created to store the name of the file once it has been created on the server.
