Always downloads same file
I have a recordset that holds upploaded documents and the uploads work great. But when using the downloads feature it always downloads the same file no matter which file you want to download?
in the repeat region when you add the download button, add a form tag, the button and a hidden form element. Set the initial value of the hidden form element to use the file name column from the recordset.
in the download behavior, bind the file name to the hidden form element.
Doh! Of course ... I knew that. Thanks.
But now onto the upload file renaming issue ......
