DataAssist or UE4 problem
Thread began 11/26/2011 5:13 pm by Kumel | Last modified 1/02/2012 6:37 am by Kumel | 938 views | 7 replies |
Kumel
I have insert insert & result page using dataassist & then applied UE4 for uploading files.. So everything is fine now.. but then when a user doesnt choose any file & if he just clicks UPLOAD BUTTON that gets stored in DB. I mean not the file.. File name & etc are empty.. but it doesnt show any error like "NO IMAGE UPLOADED" or etc.. how do we show that?
see the "Customizing Error Messages" tutorial on the Universal Email support landing page:
universal-email/
Kumel
ok.. thanks about that...
Need solution for below thread:
If user inserts a record & then can he edit only his records from resultpage? like can he add a comment? only he must be able to add comment to dat record which he inserted...?
is dat possible?
your question is illegible.
Kumel
Ok when i didnt apply above stuff to my page but then i used SERVER REDIRECT when Upload FAIL. So by that the user gets redirected to other page.. But the RECORD gets inserted in DB.. i have attached the file please look into it..
upload.zip
Kumel
ANother thing i want to know is,
there are two field to enter. 1 is IMG & another is a text .. Both records get inserted to the DB.. text field is not *REQUIRED.. so in DB. by default i kept the value as //- No Comments -// so when the user uploads a file & doesnt enter any text in text field, so in DB it must show NO COMMENTS so this is not happening.. its not working. so can you temme what needs to be done.. please check the above field ATTACHED.
Ian S
Just out of interest, why don't you just leave the Comments field blank if no comments are entered?
What is the purpose of having a default value of //- No Comments -//?
Ian
Kumel
I need that to be the default value..
