Error message when trying to edit a menu
Hi, I successfully created a navigation bar with CSS Menu Writer, but, when I try to edit the navigation bar in any way I get an error message from Dreamweaver CS4 that says: "Error generating menu (wa.generate.menu): Process type "undefined" not found."
What do I need to do to be able to edit the menu?
Please note that, as indicated in another thread on this topic in the CSS Menu Writer forum, I deleted the WinFileCache.dat file, but that didn't help. I also uninstalled CSS Menu Writer, re-installed it, deleted the WinFileCahe.dat file, but that didn't help either.
I've read through the existing problem but there is no solution posted in the forum. Please advice. Thanks
