PayPal IPN not working
Thread began 11/23/2011 3:52 am by ccdantas101117 | Last modified 9/18/2018 3:56 pm by Ray Borduin | 2640 views | 3 replies |
ccdantas101117
Hello everybody, if anyone can give me a clue what am I missing here because it is not working.
I have created an IPN response page, activate IPN and point to the proper URL and when I run a transaction it doesn't work. The IPN page has an order update info update and send email to customer. Please help here.
IPN RESPONSE PAGE CODE BELOW:
<?php require_once('Connections/phdconn.php'); ?>
//WA eCart Include
require_once("WA_eCart/phdCart_PHP.php");
$phdCart->GetContent();
//WA eCart Include
require_once("WA_eCart/WA_eCart_Database_PHP.php");
<?php require_once("WA_Universal_Email/mail_PHP.php"); ?>
<?php require_once("WA_Universal_Email/MailFormatting_PHP.php"); ?>
// WA eCart Get Form PaypalIPN.xml
if (WA_isValidPayPal()) {
$phdCart->ClearCart();
$displayIndex = 0;
$runOnce = "run";
while (isset($_POST["item_number".($displayIndex+1)])) {
$ATC_AddIfIn = 0;
$ATC_RedirectIfIn = "";
$ATC_ID = "".$_POST["item_number".($displayIndex+1)] ."";
$ATC_Name = "".$_POST["item_name".($displayIndex+1)] ."";
$ATC_Description = "";
$ATC_Weight = "0";
$ATC_Quantity = "".$_POST["quantity".($displayIndex+1)] ."";
$ATC_Price = "".$_POST["mc_gross_".($displayIndex+1)]/$_POST["quantity".($displayIndex+1)] ."";
$ATC_size = "";
$ATC_SizePriceInc = "0";
$ATC_color = "";
$ATC_ColorPriceInc = "0";
$ATC_Thumbnail = "";
$ATC_shipusa = "0";
$ATC_shipintl = "0";
$ATC_specialIn = "0";
$ATC_Specials = "0";
$ATC_specQty = "0";
if (is_numeric($ATC_Quantity) && $ATC_Quantity != 0) {
$phdCart->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_ID, $ATC_Name, $ATC_Description, $ATC_Weight, $ATC_Quantity, $ATC_Price, $ATC_size, $ATC_SizePriceInc, $ATC_color, $ATC_ColorPriceInc, $ATC_Thumbnail, $ATC_shipusa, $ATC_shipintl, $ATC_specialIn, $ATC_Specials, $ATC_specQty);
$runOnce = null;
$displayIndex++;
// WA eCart Store Cart Summary in Db
if (WA_isValidPayPal()) // Trigger
$WA_connection = $phdconn;
$WA_table = "orders";
$WA_redirectURL = "";
$WA_indexField = "OrderID";
$WA_fieldNamesStr = "OrderID|OrderReferenceID|OrderPaypalID|OrderPaypalStatus|OrderStatus";
$WA_fieldValuesStr = WA_eCDB_ConvertNumber("".((isset($_POST["invoice"]))?$_POST["invoice"]:"") ."") . "|" . "PHD".data("Y") ."".((isset($_POST["invoice"]))?$_POST["invoice"]:"") ."" . "|" . "".((isset($_POST["txn_id"]))?$_POST["txn_id"]:"") ."" . "|" . "".((isset($_POST["payment_status"]))?$_POST["payment_status"]:"") ."" . "|" . WA_eCDB_ConvertNumber("1");
$WA_columnTypesStr = "none,none,NULL|',none,''|',none,''|',none,''|none,none,NULL";
$WA_sessionName = "OrderID";
$WA_Sql = "";
$NeedInsert = false;
$indexFieldIndex = -1;
$WA_connectionDB = $database_phdconn;
$updateFieldValue = "";
if ($WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos('?', $WA_redirectURL) === false)?"?":"&").$_SERVER["QUERY_STRING"];
for ($i = 0; $i < sizeof($WA_fieldNames); $i++)
if ($WA_indexField == $WA_fieldNames[$i])
$indexFieldIndex = $i;
break;
$deleteFieldValue = "";
$updateColType = "none,none,NULL";
if ($indexFieldIndex >= 0) $updateFieldValue = $WA_fieldValues[$indexFieldIndex];
if ($updateFieldValue == "" && isset($_SESSION[$WA_sessionName])) $updateFieldValue = $_SESSION[$WA_sessionName];
if ($indexFieldIndex >= 0) $updateColType = $WA_columns[$indexFieldIndex];
if ($updateFieldValue != "") {
$updateParamsObj = WA_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, $indexFieldIndex);
$valueForWhere = WA_generateInsertParams(array($WA_indexField), array($updateColType), array($updateFieldValue), -1);
$WA_Sql = "update " . $WA_table . " SET " . $updateParamsObj->WA_setValues . " where " . $WA_indexField . " = " . $valueForWhere->WA_dbValues;
$WA_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
$_SESSION[$WA_sessionName] = $updateFieldValue;
$result = mysql_query("SELECT * FROM " . $WA_table . " where " . $WA_indexField . " = " . $valueForWhere->WA_dbValues, $WA_connection);
$num_rows = mysql_num_rows($result);
$NeedInsert = (mysql_num_rows($result) === 0);
if ($updateFieldValue === "" || $NeedInsert) {
$insertParamsObj = WA_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "insert into " . $WA_table . " (" . $insertParamsObj->WA_tableValues . ") values (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
header("Location: ".$WA_redirectURL); exit;
if ((WA_isValidPayPal())) {
//WA Universal Email object="mail"
//Send Loop Once Per Entry
$RecipientEmail = "".((isset($_POST["payer_email"]))?$_POST["payer_email"]:"") ."";include("WA_Universal_Email/WAUE_ipnresponse_1.php");
$RecipientEmail = "sales@princesshairdesigns.com";include("WA_Universal_Email/WAUE_ipnresponse_1.php");
$RecipientEmail = "ccdantas@ccdantaswebdesign.com";include("WA_Universal_Email/WAUE_ipnresponse_1.php");
//Send Mail All Entries
if (""!="") {
header("Location: ");
// WA eCart Redirect
if ($phdCart->redirStr != "") {
header("Location: ".$phdCart->redirStr);
Dani Chankhour
It is really difficult to debug IPN, but the most important thing is to make sure an IPN is being sent correctly.
In your PayPal account, under the Profile, there is a link to an IPN History page which lists all the Notifications to your site. Check that page and ensure there is an IPN that was made once the purchase was made and that that it was made to the correct url.
The second thing i recommend is that you simplify the page. Once you confirm there is an IPN, i recommend that you only send a Static email address to ensure IPN is working. And then you can go back and try to insert the order to the database.
msjj000Beta Tester
IPN or Other error when using PayPal
Hi Webassit,
I am using PS454 from a fresh install. I have recently moved form eway (site all working fine) to PayPal standard. I have entered in the IPN URL as httpS and not http as the site only uses https pages being redirected that way (under settings it is listed as my site with an http).
In PayPal I can see that there is IPN history.
So, my question is, sales don't get recorded in PS. I find out about sales via PayPal app notifications so I am needing to enter each sale manually. This happens regardless of whether the URL in PayPal's IPN is there or not. I haven't tried this as yet in PayPal express as the PayPal standard process appears smoother.
If i click on return to seller's site, it does and goes to the check_success page however the transaction ID looks like one from when the site is in test mode.
// ignore as working now - some kind of delay Secondly, are "Welcome to our site" upon registration emails are not being sent upon registration.
Thanks.
Check the FROM url for the welcome to the site messages. Make sure it is a valid email address from the same domain as your site.
