Create New Template
From an existing page Icreated a new template in DW
When I open the template in DW most items are locked so cannot be changed.
Can I unlock these items.
Thank You
John
Thank You
John
If you want to change the Template structure, you can go to Modify -> Templates -> Detach from Templates and adjust the template accordingly. Basically you are recreating the Template file.
