bug with DW CS4 template and HTML5?
Thread begun 11/22/2011 10:56 am by Massimo | Last modified 4/23/2013 1:47 am by Massimo | 2431 views | 4 replies |
Massimo
I work with CS4 template and all is ok, but when try to use it with html5 the template delete all php code above html declaration in all file. Example:
so work well in my examplefile.php: when updating template the file are updated well.
<?php require_once('../language/myfile.php'); ?>
<?php require_once('../include/myfile2.php'); ?>
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/2011.dwt.php" codeOutsideHTMLIsLocked="false" -->
But if I change
<html xmlns="http://www.w3.org/1999/xhtml"> to
<!doctype html>
when updating examplefile.php the file is so:
<!doctype html>
and all above is deteled!
I think this is a bug, nobody know a solution?
Dani Chankhour
Adobe released DW CS 5.5 which Supports HTML5, which explains why that could be an issue with DW CS4.
Massimo
I know that CS5.5 are better but now don't would like buy it, however I have resolved leaving the old html declaration until I use the template and replacing it with the html5 declaration when finished to build the site.
I know it is not very comfortable but I have not found other solutions for cs4
S.WebAssist447033
You don't need to revert to a pre-HTML5 DOCTYPE: you simply need to explicitly include an <html> tag (which is optional in HTML, and should be inferred if not included, but appears to be required by Dreamweaver when it's determining what is code outside of the <html> element).
So this works:
<!doctype html>
<html>
Your XHTML1.0 version worked because your XHTML boilerplate included an <html> tag.
Thank you for posting this, by the way. We were struggling with the same problem, and your mention of it working in XHTML1.0 was enough of a hint to help us to solve it.
Massimo
Thanks!
