count times an item is viewed
Thread began 11/21/2011 7:54 am by Jedi | Last modified 12/08/2011 2:29 pm by Jason Byrnes | 911 views | 5 replies |
Jedi
Hi, I am setting up an ecommerce site in php and mysql that I would like to display how many times an item has been viewed. Can anyone point me in the right direction?
Thanks in advance
This is not a simple one to accomplish. it require a good understanding of creating recordsets, setting session, doing basic math in PHP and updating the database. It will require some hand coding to accomplish.
you would need to have a table that stores the view count.
it will need a column to hold the productID and the count
create a recordset to return the count column for the product using the product ID querystring to filter.
store the count in a session variable and increment it by one.
then add an update record behavior to store the new count in the database.
you can use the session to show the currant count.
We wont be able to offer a lot of help on setting this up, if you need assistance, i would suggest signing up for a premiere ticket appointment where we would be able to work with you in a one on one scenario.
Jedi
Thanks Jason,
I will give it a try and if needed I will set up a premier ticket.
Jedi
Thanks Jason for the input. I tried it and it worked perfectly!
Jedi
My mistake. I am incrementing all items by one every time. It is not inputting into the correct item.
in the update record behavior, make sure you are using the product ID querystring to tell it which item to increment the count for.
