multiple not update
I would update multiple record setting a field (confema) in my database to zero in recordset is not empty. I try many time and read many tread but not working!
This is code:
mysql_select_db($database_annunci, $annunci);
$query_rs_scaduti = "SELECT idannuncio, titolo, datainserimento, conferma FROM annuncio WHERE((select DATEDIFF(NOW(),datainserimento)) >= 61)";
$rs_scaduti = mysql_query($query_rs_scaduti, $annunci) or die(mysql_error());
$row_rs_scaduti = mysql_fetch_assoc($rs_scaduti);
$totalRows_rs_scaduti = mysql_num_rows($rs_scaduti);?>
// WA DataAssist Multiple Updates
if (!($totalRows_rs_scaduti == 0)) // Trigger
$WA_loopedIDField = array("WADA_RepeatID_idannuncio");
$WA_connection = $annunci;
$WA_table = "annuncio";
$WA_redirectURL = "";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "idannuncio";
$WA_fieldNamesStr = "conferma";
$WA_columnTypesStr = "none,none,NULL";
$WA_connectionDB = $database_annunci;
$WA_multipleUpdateCounter = 0;
while (WA_AB_checkLoopedFieldsNotBlank($WA_loopedIDField, $WA_multipleUpdateCounter)) {
$WA_fieldValuesStr = "0";
$WA_where_fieldValuesStr = WA_AB_getLoopedFieldValue($WA_loopedIDField[0], $WA_multipleUpdateCounter);
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
$WA_multipleUpdateCounter++;
if ($WA_redirectURL != "") {
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = false;
$RepeatSelectionCounter_1_Iterations = "-1";
<head>
<title>Documento senza titolo</title>
</head>
<body>
<form action="" method="post" enctype="multipart/form-data">
<table>
<?php do { ?>
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_rs_scaduti){
<tr>
<td>conferma</td>
<td><input type="hidden" name="WADA_RepeatID_idannuncio_<?php echo $RepeatSelectionCounter_1; ?>" id="WADA_RepeatID_idannuncio_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_rs_scaduti["idannuncio"]; ?>" />
<input name="conferma_<?php echo $RepeatSelectionCounter_1; ?>" type="hidden" value="0" /></td>
</tr>
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_rs_scaduti && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
<?php } while ($row_rs_scaduti = mysql_fetch_assoc($rs_scaduti)); ?>
</table>
</form>
need help!
