How do I Debug a NEW Powerstore 4.5 site?
Thread began 11/17/2011 4:44 pm by Dan808 | Last modified 11/17/2011 5:41 pm by Dan808 | 517 views | 4 replies |
Dan808
Debug is turned on while browsing www.wheezingeezer.com.
There are NO echoed errors on pages.
Is this thorough enough debugging?
Isn't there another line of code that needs to be inserted "directly" into the pages?
Do I need to do this from HTTPS: also?
Could someone at WebAssist enlighten us WebAssist users as to: How WEBASSIST would go about debugging a PowerStore 4.5 site? In detail.
(I found absolutely nothing in the forums on this topic)
Would you debug the site for me and check for all patches? (Preferable)
Many Thanks.
The store is GREAT!
there is no one way to debug the site.
what is the problem you are having?
this will determine how you go about debuging the problem.
Dan808
Debugging a PS 4.5 store is not required?
No problem with the site at all Jason.
I was under the impression that it was another step in web development used to find "hidden demons" lurking in the code.
Sort of a fail safe testing mode?
Thanks for any professional insight.
debugging is what you do when there is a problem.
Dan808
Testing not Debugging -
Yes, I guess the word I should have been using is the word testing?
"My Bad".
I will turn the site over to the client and venture out to find the "next" PowerStore client. Your professionalism, knowledge, and talent is always greatly appreciated Sir.
Thank you Jason, for all the Great Support during this build.
Dan
