eCart Vouchers
Thread began 11/16/2011 9:21 pm by david331670 | Last modified 11/18/2011 9:33 am by Jason Byrnes | 615 views | 3 replies |
david331670
eCart Vouchers
Hi
I would like to offer my customers a uniquely numbered voucher for a Gift certificate purchase. How can I have the number generated and placed in an email up dateable form field/ or html table that I can design in DW for UE.
I have a data base that collects sales info but how do I get the "auto incremental number" from a new number field in the table in the data base to insert into this field? (like the Order receipt number used after a completed transaction)
I am not sure how this is done, can you please point me in the correct direction
David
use the security assist Random Password tool.
on the bindings panel, click the plus button and select WebAssist -> Random Password.
then add a Set Session variable behavior, On the server behaviors panel, click the plus button and select eCart -> General -> Set Session Value
set the trigger to before page load, set the name to something like VoucherCode, click the lightning bolt next to value and select the random password binding.
use this session in the database and in the email to send the voucher code.
david331670
eCart Voucher
Thank you
I will give it a try.
Do I need to set up a table, field in a table in the data base to record the random password code? or is there another alternative?
How do I record the numbers. I already have a table called coupon codes but I need to record the details of the voucher recipient as well as the voucher number
the voucher code is basicly a product that you are selling, correct?
If so, set up a column in the order details table to capture the value stored in the session variable.
in the eCart Store Order Details behavior that will be created by the checkout wizard, you can bind the new column of the order details table to the session variable.
