Is there an easy way to add an auto-fill to a form
Thread began 11/11/2011 10:48 am by blakebenjamin327842 | Last modified 11/14/2011 12:12 pm by Jason Byrnes | 727 views | 7 replies |
blakebenjamin327842
Hello All,
I am creating a site that has 3 registration levels (ie, wholesale, designer, and retail) and upon registration I would like a hidden field to auto-fill what their registration level. I have set up a separate registration form for each of the levels and just want to auto insert the level based on which form they are using.
I own all the webassist plugins, so if there is a combination of products needed I am prepared.
thanks in advance.
each form should be on a seperate page, on each page, you should have an insert record behavior, in the insert record behavior, you can set the user level for that registration page as a hard coded value.
blakebenjamin327842
Auto Fill
Jason,
Can I use CSS form builder for this?
Benjamin
yes, you could use css form builder to creat the form.
blakebenjamin327842
Jason -
I am using the registration for created by Security Assist can you please be more specific as to how I manually add in the value?
Select each form element, in the property inspector, type the value in the initial value box.
blakebenjamin327842
One last question, how can i make the field hidden?
change the type to hidden:
<input type="text"
<input type="hidden"
