php 5 required but i have php 5.2.0-8+etch16
Thread began 11/05/2011 11:34 am by JBWebWorks | Last modified 11/09/2011 7:54 am by JBWebWorks | 3561 views | 4 replies |
JBWebWorks
Just bought power gallery solution and trying to install and get this server error
PHP 5.2.0-8+etch16
PHP 5 or greater is required. Contact your hosting provider to upgrade your PHP server.
thanks for your help,
-Jim Balthrop
PHP version 5.2.3 is needed. this is the earliest version that introduced the mysql_set_charset function in php.
to work around the issue, edit the install_gallery/dignostic.php file, change:
if (strnatcmp(phpversion(),'5.2.3') >= 0){
if (strnatcmp(phpversion(),'5.2.0') >= 0){
next edit the install_gallery/global.php file, add the following code at line 1:
if (function_exists('mysql_set_charset') === false) {
     function
mysql_set_charset($charset$link_identifier null)
         if (
$link_identifier == null) {
             return
mysql_query('SET NAMES "'.$charset.'"');
         } else {
             return
mysql_query('SET NAMES "'.$charset.'"'$link_identifier);
add the same code at line 1 of the install_gallery/scripts/connection.php file.
after the install is complete, you may need to edit the Connections/powergallery.php and add that code block again at line 1.
JBWebWorks
Jason,
should Power Gallery be installed on local testing server also?
"should" isn't really the correct question.
Power Gallery _can_ be installed on a local testing server, but it doesn't _have_ to be. it is entirely up to you.
JBWebWorks
thanks Jason
