Where is the CSS rule located in the Crazy Theme for changing block ps_highlight?
Thread began 11/05/2011 6:10 am by Dan808 | Last modified 11/07/2011 10:05 am by Jason Byrnes | 454 views | 1 replies |
Dan808
Where is the CSS rule located in the Crazy Theme for changing block ps_highlight color?
The (block ps_highlight) color is medium gray right now and the outer box (ps_main ps_pod4) is darker gray.
I want to change the color of the block ps_highlight to a different color or possibly add a background image to it instead.
Dan
Sorry for the double post.
You can use the FireBug plugin for Fire Fox to inspect the document model and select specific elements on the page to find the css controlling that element.
If you need further help, send a link to your page.
