Email errors with Universal Emailer
Thread began 11/04/2011 9:39 pm by illbe322016 | Last modified 11/08/2011 10:53 am by Jason Byrnes | 679 views | 3 replies |
illbe322016
I have a form page that submits values to a db, the result is shown on a results page. I want the results page to display the correct info to the user and also send a copy of the page to his email (provided in the form). I keep getting this error:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent
I know it has to do with the order of the code but I'm not sure how. I have included the code below, any help is much appreciated.
Tom
<head>
<?php if (!isset($_SESSION))session_start();
if (($_SERVER["REQUEST_METHOD"] == "POST")) {
//WA Universal Email object="mail"
set_time_limit(0);
$EmailRef = "waue_quoteResult_2";
$BurstSize = 200;
$BurstTime = 1;
$WaitTime = 1;
$GoToPage = "quoteResultSent.php";
$RecipArray = array();
$StartBurst = time();
$LoopCount = 0;
$TotalEmails = 0;
$RecipIndex = 0;
// build up recipients array
$CurIndex = sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
$RecipArray[$CurIndex ][] = $_POST['email'];;
$TotalEmails += sizeof($RecipArray[$CurIndex]);
$RealWait = ($WaitTime<0.25)?0.25:($WaitTime+0.1);
$TimeTracker = Array();
$TotalBursts = floor($TotalEmails/$BurstSize);
$AfterBursts = $TotalEmails % $BurstSize;
$TimeRemaining = ($TotalBursts * $BurstTime) + ($AfterBursts*$RealWait);
if ($TimeRemaining < ($TotalEmails*$RealWait) ) {
$TimeRemaining = $TotalEmails*$RealWait;
$_SESSION[$EmailRef."_Total"] = $TotalEmails;
$_SESSION[$EmailRef."_Index"] = 0;
$_SESSION[$EmailRef."_Remaining"] = $TimeRemaining;
while ($RecipIndex < sizeof($RecipArray)) {
$EnteredValue = is_string($RecipArray[$RecipIndex][0]);
$CurIndex = 0;
while (($EnteredValue && $CurIndex < sizeof($RecipArray[$RecipIndex])) || (!$EnteredValue && $RecipArray[$RecipIndex][0])) {
$starttime = microtime_float();
if ($EnteredValue) {
$RecipientEmail = $RecipArray[$RecipIndex][$CurIndex];
} else {
$RecipientEmail = $RecipArray[$RecipIndex][0][$RecipArray[$RecipIndex][2]];
$EmailsRemaining = ($TotalEmails- $LoopCount);
$BurstsRemaining = ceil(($EmailsRemaining-$AfterBursts)/$BurstSize);
$IntoBurst = ($EmailsRemaining-$AfterBursts) % $BurstSize;
if ($AfterBursts<$EmailsRemaining) $IntoBurst = 0;
$TimeRemaining = ($BurstsRemaining * $BurstTime * 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts>$EmailsRemaining)?0:($IntoBurst*$RealWait));
if ($TimeRemaining < ($EmailsRemaining*$RealWait) ) {
$TimeRemaining = $EmailsRemaining*$RealWait;
$CurIndex ++;
$LoopCount ++;
session_commit();
session_start();
$_SESSION[$EmailRef."_Index"] = $LoopCount;
$_SESSION[$EmailRef."_Remaining"] = round($TimeRemaining);
session_commit();
wa_sleep($WaitTime);
include("webassist/email/waue_quoteResult_2.php");
$endtime = microtime_float();
$TimeTracker[] =$endtime - $starttime;
$RealWait = array_sum($TimeTracker)/sizeof($TimeTracker);
if ($LoopCount % $BurstSize == 0) {
$TimePassed = (time() - $StartBurst);
if ($TimePassed < ($BurstTime*60)) {
$WaitBurst = ($BurstTime*60) -$TimePassed;
wa_sleep($WaitBurst);
else {
$TimeRemaining = ($TotalEmails- $LoopCount)*$RealWait;
if (!$EnteredValue) {
$RecipArray[$RecipIndex][0] = mysql_fetch_assoc($RecipArray[$RecipIndex][1]);
$RecipIndex ++;
$_SESSION[$EmailRef."_Total"] = 0;
$_SESSION[$EmailRef."_Remaining"] = 0;
session_commit();
session_start();
if ($GoToPage!="") {
header("Location: ".$GoToPage);
<?php require_once("webassist/email/mailformatting_php.php");?>
<?php require_once("webassist/email/mail_php.php");?>
<?php require_once('Connections/PYAConnection.php'); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$airModel_rsResult = "Null";
if (isset($airModel)) {
$airModel_rsResult = (get_magic_quotes_gpc()) ? $airModel : addslashes($airModel);
mysql_select_db($database_PYAConnection, $PYAConnection);
$query_rsResult = sprintf("SELECT * FROM pyaData WHERE pyaData.aircraft_model = %s", GetSQLValueString($airModel_rsResult, "text"));
$rsResult = mysql_query($query_rsResult, $PYAConnection) or die(mysql_error());
$row_rsResult = mysql_fetch_assoc($rsResult);
$totalRows_rsResult = mysql_num_rows($rsResult);
the php code block for the universal email behavior needs to be before the doctype tag and any other html code on your page.
illbe322016
Still struggling
OK, managed to get rid of the errors (Thanks Jason), I now have:
A form the user submits that retreives a record from the db, this submits to a processing page (with the UE script) that holds the info from the db, I then have a form at the bottom that auto-submits form variables to a display page, showing the retrieved info to the user. If I use the "any form post" choice in UE it sends me an email WITHOUT the posted form data. I know the form works because I used a submit button to test it and I got the form WITH the posted form data. I'm fairly sure that the reason it doesn't show dynamic data with the "any form post" selection is that it sends the email after seeing the first post from the first form. None of the other choices send the email. I would like to send the email with the dynamic data to the user AND display the dynamic data for the user too. What the heck am I doing wrong?
send a copy of the -age that does work, the page that does not work and the webassist/email folder in a zip archive so I can see the code.
