Error displayed if image file extension in uppercase
Thread began 11/04/2011 2:14 pm by nibo | Last modified 11/08/2011 9:47 am by Jason Byrnes | 4550 views | 5 replies |
nibo
I have just uploaded updates to a site from my local server to a development server and I got a lot of warning messages like:
Warning: imagejpeg() [function.imagejpeg]: Unable to open '/<snip>
Permission denied in ../CacheResize_Image.php on line 212
Some of the thumbnails generated by Image Resized were fine, but the others had the error message. I traced it to the fact that the images that were not displaying had an uppercase file extension (.JPG not .jpg).
I changed the file extension of the ORIGINAL file that I had uploaded (not the one in the image_cache folder) AND changed the file extension in the database record and refreshed the page. Now they work.
As I am using File Manager to upload the image that Image Resizer then uses to create the thumbnails, I would like to know if it's possible to force the uploaded file to have a lowercase extension. I have posted a question to the HTML Editor forum.
Dani Chankhour
I posted a work around in the HTML Editor thread.
However i can't reproduce the issue where image image resizer does not work with upper case extension.
Is there a page where i can see the issue, or you can zip the file and attach it to the thread along with the image that is causing the issue and the image resizer file.
thanks.
nibo
Hi Dani,
Thanks for the response.
As I have fixed all the problem image files there are no errors to see at the moment. I have added the strtolower() fix to the ulpoad.php file as you mentioned in the other thread, however I will revert to the original file and try uploading an image with an uppercase extensions and see what happens.
Both upper and lower case file extensions were working fine on my local Apache server so perhaps it's a setting on the other web server?
Dani Chankhour
That is possible, although i have not heard of any setting on a Server that could affect lower/upper file extensions.
Let me know if you come across the issue again.
nibo
I am seeing the error again. It's not in the same area of the site as before, but shows the same error message.
Warning: unlink(image_cache/assets/companies/proportion/logo_philjonesbass_w90_h68/logo_philjonesbass_07250315.jpg) [function.unlink]: Permission denied in /var/www/vhosts/dev.mydomain.com/httpdocs/webassist/caching/CachedResize_Image.php on line 269
Warning: imagejpeg() [function.imagejpeg]: Unable to open 'image_cache/assets/companies/proportion/logo_philjonesbass_w90_h68/logo_philjonesbass_07250215.jpg' for writing: Permission denied in /var/www/vhosts/dev.mydomain.com/httpdocs/webassist/caching/CachedResize_Image.php on line 207
This time it doesn't seem to be related to uppercase file extensions. There are only four images which always show the error. The other images display correctly.
Weirdly, on a different page set-up to show all available images for that section, the ones which normally don't show, do show. ???
Any thoughts very much appreciated.
