errors while modifying themes
Thread began 11/03/2011 4:24 pm by eddieor_411429784 | Last modified 11/03/2011 5:25 pm by Jason Byrnes | 960 views | 1 replies |
eddieor_411429784
just purchased powerstore today. had some problems installing but finally got it going. keep getting these errors when i try to modify a theme.
i've set directory rights to 777
i didn't install on the root instead created a /store directory.
Warning: fopen(../../themes/temp_editing/css/configurable.css) [function.fopen]: failed to open stream: No such file or directory in /home/content/19/7610719/html/store/webassist/plugins/styler/styler.php on line 99
Warning: filesize() [function.filesize]: stat failed for ../../themes/temp_editing/css/configurable.css in /home/content/19/7610719/html/store/webassist/plugins/styler/styler.php on line 100
Warning: fread(): supplied argument is not a valid stream resource in /home/content/19/7610719/html/store/webassist/plugins/styler/styler.php on line 100
Warning: fclose(): supplied argument is not a valid stream resource in /home/content/19/7610719/html/store/webassist/plugins/styler/styler.php on line 101
Warning: simplexml_load_file() [function.simplexml-load-file]: I/O warning : failed to load external entity "../../themes/temp_editing/theme_settings.xml" in /home/content/19/7610719/html/store/webassist/plugins/styler/styler.php on line 104
Fatal error: Call to a member function asXML() on a non-object in /home/content/19/7610719/html/store/webassist/plugins/styler/styler.php on line 117
delete the webassist/themes/temp_editing folder, it will get recreated the next time you try to edit a theme.
