eCart Error
Thread began 11/02/2011 2:08 pm by goat200487425014 | Last modified 12/02/2011 6:57 am by Jason Byrnes | 1518 views | 5 replies |
goat200487425014
eCart Error
I am having this error show up when I try to create a recordset. Can you help me with this?
Also when I try to access your website, it says that maybe I should login and it says forbidden..... I have to click on a link that I saved for a post and then access webassist.com and then about a minute later, it says I'm forbidden again!!!
goat200487425014
I really need to get this resolved, so I can continue to make my cart!!!!!
goat200487425014
Ticket has been updated....
info4753
Got the same error with 5.0.3. I even get Javascrip eorro when I try to delete the server behaviour.
(I wonder why solutions are not published here or in a tutorial database.)
here is an updated copy of the Configuration/ServerBehaviors/Shared/WA_eCart_Shipping_Shared.js file that should correct the sissue.
It will need to be copied to the users ServerBehaviors/Shared directory in the users configuration folder.
for help locating the users configuration folder, see the com,mon installation issues PDF:
WA_eCart_Shipping_Shared.js.zip
