Transferred host and can no longer log in
Thread began 11/01/2011 1:09 pm by drook431907 | Last modified 11/01/2011 2:36 pm by Jason Byrnes | 1589 views | 3 replies |
drook431907
I am working on a site that someone else has done. It was just recently moved to godaddy and now when I attempt to login, I get the following:
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/content/97/8368397/html/includes/login/Helper_PHP.php on line 16
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/content/97/8368397/html/includes/login/Helper_PHP.php on line 22
Table 'astrec.your_tablename' doesn't exist
When I go to Helper_PHP.php, here are lines 11-24:
$WA_Auth_Separator = "|§|";
function WA_AuthenticateUser($WA_Auth_Parameter){
$UserAuthenticated = false;
mysql_select_db($WA_Auth_Parameter["database"], $WA_Auth_Parameter["connection"]); -------------(LINE 16)
$WA_Auth_loginSQL = "SELECT `".implode('`,`', $WA_Auth_Parameter["sessionColumns"])."` FROM `".$WA_Auth_Parameter["tableName"]."` WHERE ";
for($idx=0;$idx<count($WA_Auth_Parameter["columns"]);$idx++){
$WA_Auth_loginSQL = sprintf($WA_Auth_loginSQL.(($idx!=0)?" AND ":" ")."`%s`=%s ", $WA_Auth_Parameter["columns"][$idx], WA_GetSQLValueString($WA_Auth_Parameter["columnValues"][$idx], $WA_Auth_Parameter["columnTypes"][$idx]));
$WA_Auth_RS = mysql_query($WA_Auth_loginSQL, $WA_Auth_Parameter["connection"]) or die(mysql_error()); -------------(LINE 22)
$WA_Auth_Rows = mysql_num_rows($WA_Auth_RS);
I'm a newbie, any suggestions?? Thanks.
you will need to edit the Connections/localhost.php file to pint to the database on the GoDaddy MySQL server.
drook431907
Based on godaddy specs, my localhost.php is actually astrec.php and this is their suggested code that I have in that file.
//Connect To Database
$hostname='astrec.db.8368397.hostedresource.com';
$username='astrec';
$password='SpaceTech2011';
$dbname='astrec';
$usertable='your_tablename';
$yourfield = 'your_field';
mysql_connect($hostname,$username, $password) OR DIE ('Unable to connect to database! Please try again later.');
mysql_select_db($dbname);
$query = 'SELECT * FROM ' . $usertable;
$result = mysql_query($query);
if($result) {
while($row = mysql_fetch_array($result)){
$name = $row[$yourfield];
echo 'Name: ' . $name;
the user registration solution pack uses the Connections/localhost.php file to connect to the database.
you will need to update that connection file with the correct information to connect to the database on the go daddy server.
