Not working
Thread begun 10/31/2011 7:05 am by info4753 | Last modified 11/01/2011 10:01 am by Jason Byrnes | 2321 views | 1 replies |
info4753
Not working
If I change the preset, the button on the page is not being changed. Only if I reapply the button.
Also, hover is not working. No :hover styles are being applied nor any javascript files.
to edit an existing button, select it in design view, then go to Webassist -> CSS Button Styler -> Insert Button.
The style applied to the button are set by the class attribute, when the design is changed, the class attribute also needs to be changed.
can you send a link where i can see the issue with the hover, how are you setting the hover options in the Button Styler interface?
