Wrap text in sub menus
Thread began 10/28/2011 3:43 pm by randy294090 | Last modified 10/28/2011 5:12 pm by Jason Byrnes | 668 views | 1 replies |
randy294090
I'd like to be able to wrap the text in my sub menus. Is there a easy to do this? I did not see a setting for this in the tool.
Here is my site welcome.php
I have a variety of sub menu header lengths. I've had to make the font rather small to accomodate most of them. You can see that some menu items still hang over the width of the menu field. I'd like to word wrap the text and make the font larger and easier to read.
Thanks,
Randy
one of the problems with this is that when the words do wrap, it cannot dynamicly set the hight of the container.
This means that you need to set the height of the menu items to something like 30px to allow for the second line. the height needs to be set to give the line a place to wrap to, other =wise, the line will wrap, but it wont be seen, because it will fall outside of the container available to the link text.
then in the css you can add a white-space: normal; setting to wrap the text.
