MS access databases
Are there any limitations to using webassist extensions with MS access databases? Are all extensions compatable with access?
No, not all extensions are compatible with access, most are not.
Most of the extensions will only work with PHP / MySQL
Please could you list the extensions that do work with access?
Also any suggestions for creating a dynamic site using supersuite that can only use an access database.
The only extensions that will allow for ussing an access database are:
DataAssist
Dynamic Web Charts
Pro Maps for Google
all other extensions support PHP / mySQL Only.
Using those extesnions, the only way to use an access database is with ASP or Cold Fusion page types, Dreamweaver will not allow for connecting to an Access database using the PHP page type.
Using an Access database is not supported with Supper Suite.
