Multiple Shipping instances added to cart
PROBLEM:
My client has asked that I include a single flat rate of £42 for shipping. I've set this up in the shipping option of the checkout wizard and in the eCart object. When I test this, even with only one item in the cart, I get multiple instances of shipping being added to the checkout page.
In fact I get 11 instances of £42 showing up, and being totaled to £462!
Looking in the shipping tab of the eCart object (in edit mode), my shipping and handling £42 flat rate rule is there 11 times. I didn't add it 11 times, but I guess this does explain why I'm getting 11 instances of shipping added during checkout.
Problem is I don't seem to be able to delete this shipping rule from the eCart object. If I select the first instance of the rule and delete it, all 11 instances seem to be deleted - but when I click OK to leave the eCart object I get this JavaScript Error:
"While executing onClick in WA eCart Object.htm, a Javascript error occurred"
The only way I can leave the eCart object is to click Cancel - which means the problem rule(s) are not deleted.
SOLUTION:
I've managed to get round the problem for now by adding a new shipping rule and making the problem one(s) inactive. I noted that when I make one instance of this inactive all eleven instances become inactive.
My new rule works fine - but I thought I'd report this here in case anyone else is having this problem and / or knows of a way to remove these miscreant rules from the eCart Object.
