dynamic connections
Hi
is there any reason why I cannot use dynamic connections to run a local copy and a remote live copy of ps4 so that I can modify the design locally?
thanks
Ian
Hi
thanks
Ian
No, I dont see any problem using Dynamic Connections with power store, as long as the connection is named PowerStoreConnection, it should be fine.
