php errors in contact form
Thread began 10/18/2011 4:33 pm by scott417485 | Last modified 10/19/2011 6:55 pm by scott417485 | 1262 views | 2 replies |
scott417485
Hi Guys
I have two site that have been runing for about 6 month all OK, this morning both of them have errors when submitting a FB contact form as per:
"Warning: set_time_limit() [function.set-time-limit]: Cannot set time limit in safe mode in /home/humanemo/public_html/contact.php on line 25
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/humanemo/public_html/contact.php:25) in /home/humanemo/public_html/contact.php on line 73
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/humanemo/public_html/contact.php:25) in /home/humanemo/public_html/contact.php on line 73
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/humanemo/public_html/contact.php:25) in /home/humanemo/public_html/webassist/email/mail_php.php on line 274
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/humanemo/public_html/contact.php:25) in /home/humanemo/public_html/webassist/email/mail_php.php on line 274
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/humanemo/public_html/contact.php:25) in /home/humanemo/public_html/contact.php on line 103
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/humanemo/public_html/contact.php:25) in /home/humanemo/public_html/contact.php on line 103
Warning: Cannot modify header information - headers already sent by (output started at /home/humanemo/public_html/contact.php:25) in /home/humanemo/public_html/contact.php on line 105"
domains are humanemousetrap.com.au and humanebugcatcher.com
Any advice would be greatly appreciated
cheers
scott
the first error is causing the other errors on the page, so that one realy the only important one.
the first error is:
This means that the host has turned Safe Mode on in the php.ini file.
CSS Form builder will not work in an environment with safe mode turned on. Turning safe mode on disables some of the functions needed by the portion of Form Builder that sends the email, in this case the set-time-limit() is the disabled function.
For CSS Form builder to function properly, Safe Mode will need to be turned off on the php server, you will need to contact the host about this.
scott417485
Hi Jason
Many thanks have asked our client to speak to their host provider.
cheers
scott
