Map help needed - pan/zoom & custom info window
Thread began 10/17/2011 5:41 pm by updates431096 | Last modified 10/18/2011 7:08 am by asnw0764437428 | 1120 views | 1 replies |
couple questions...
1. Why is it that I modify text in a custom Info window, save/upload it and it works, but then it reverts back to older text after I upload another change?
2. When I add addresses (static) or make changes using dreamweaver, which files do I need to upload? all of these?
and the html page
????any others???
3. I use this map to show locations of properties that are available for rent. Each time I add a new property, do I have to have to add the map.setZoom(9); code? Can't this just be added to one spot on the wagmp_map_1.js and zoom to that level everytime?
4. I set the controls to Pan/Zoom (large pan zoom), but it keeps displaying the small version.
The current test page I am working on is
Thank you
If you make custom changes to any of the files Pro Maps creates, then re-edit the map, those custom changes will be lost.
I would advise that you use a database to add locations. That way any new locations you add to the map via a database will not affect the files (custom or not) that Pro Maps creates.
