Unexpected Error:-3
Thread began 10/15/2011 9:28 am by donhughes428355 | Last modified 10/17/2011 10:16 am by donhughes428355 | 1291 views | 2 replies |
donhughes428355
Unexpected Error:-3
I've uninstalled some extensions and re-installed Security Assist as that is what I need most. Upon re-installing and entering my Serial # correctly, I get a message, "Unexpected Error:-3." Can someone please advise me as to what I need to do to get this back in working order.
Thank you,
Don
Are you getting the serial number for security assist from the download center or from another resource?
Make sure to use the serial number from the download center.
make sure to copy the entire string, place your cursor in the first box of the activation screen and paste the serial number, do not enter it manually.
if you are following these steps and still getting the same error, I will start an incident for you so we can investigate the problem.
donhughes428355
The cut and paste solution worked. Thank you.
