MUSE dynamicsuite
Hi, I send you an email a couple of days ago asking if your Dynamic Suite is compatible with Adobes new program MUSE, if so if could paste/import it as an widget? Or do I have to export the site from MUSE to Dreamweaver 5.5 and how will the suite work with the imported MUSE site in Dreamweaver. You can see my "Under construction site" and the code at: byairmail.net. This site is imported from MUSE into Dreamweaver 5.5
Lauren H.: The extensions are not compatible with Muse. They are made to be used with Dreamweaver exclusively
What a pity! Can I use it on the site after it`s been exported as HTML into Dreamweaver? I mean open the site in Dreamweaver and then start using Dynamic.. on the site or is there anyway to copy the codes and paste the codes into the site? If there is do you know how to split up the code and where to paste it?
Thanks for your help, One more thing: Say I creat the the site in muse.Import it into Deramweaver Links from it to pages made in dreamweaver. You think I could use these sites as a kind of "susite" and implement Dynamic suite on them?
Jan-Gunnar
Email: krs.kiris@bredband.net
