Page to send email no longer working in Dreamweaver CS4
Thread began 10/11/2011 1:06 pm by phebberd116714 | Last modified 10/11/2011 1:42 pm by phebberd116714 | 606 views | 1 replies |
phebberd116714
I have a page that I created a while back that uses Universal Email to send an encrypted password.
On my work Mac using CS5 when I open the page, I can see the behaviour.
When I use my home laptop using CS4 I get the following error message and the behavour is not in the list:
While executing findServerBehaviours in CreateEmailMessage_WA.htm a JavaScript error occurred.
I have removed and reinstalled Universal Email but I still get the same error.
The page does work when using in a browser.
Attached is the page in question, is it the code or the Dreamweaver extension causing the problem.
Help, please.
adminUsers_Registration.php.zip
phebberd116714
Problem Solved
Completely my fault.
When I updated the xml file I renamed the original as a backup in case the new file was corrupted. So the error was being caused because the config file was looking for the wrong xml file.
When I deleted the renamed file, the page loads in Dreamweaver just fine.
Maybe this should serve as a warning not to mess around with the library files :-(
