Error Log Messages
Thread began 10/10/2011 12:04 pm by jam396972 | Last modified 10/11/2011 5:30 am by jam396972 | 1744 views | 4 replies |
jam396972
Error Log Messages
Hi Jason,
I've been getting error messages on my PHP error logs that pertain to the code after the closing </html>
The code is:
<?php mysql_free_result($WADAitems); ?>
The log error messages are:
[09-Oct-2011 08:29:14] PHP Warning: mysql_free_result(): 7 is not a valid MySQL result resource in /*******/******/**_Detail.php on line 429
And on Source View:
Warning: mysql_free_result(): 7 is not a valid MySQL result resource in /****/****/******/****_Detail.php on line 343
I spoke with Hostmonster regarding this, and they are not sure if this code is necessary. I am also wondering if the code should be within the HEAD, BODY, HTML tags. When I was setting up the pages, the "body" code never went into the correct editable template tags and I had to move it around. The code that came after the ending </html> tag, I left as is. Please let me know if it should be moved or can be removed. A similar error shows up for the cart.php page as well.
Thank you
that code is in place to remove the contents of a recordset from the servers memory
if the is a recordset on the page named:
WADAitems
then the code should be left in place, unless, it is duplicated.
jam396972
Error Logs Messages
Hi Jason,
I am attaching a typical Results page and Details page. The recordset is named WADAitems. On the details pages, I see that mysql_free_result($WADAitems); is also found on line 196. This is the way the pages were created. Can I remove the code on line 196? Is this a duplication or should it be in both places? Thank you
ErrorLogs.zip
delete the instance at 196, only the instance after the </html> tag is needed.
jam396972
Error Logs Messages
Thanks Jason!
