data assist search using select list
i would like to add search using a select list. in the seach page and results.
having problems i uploaded the page.
on the results page, go to the bindings panel, click the plus button and select "URL Variable" name it "S_gallery_name"
on the server behaviors panel, click the plus button and select Data Assist -> dataAssist Search
for the trigger, click the lightning bolt and select the S_gallery_name URL Variable.
next add a new criteria, select the gallery name column.
For Filter type select List.
For List Field Name, click the lightning bot icon and select the S_gallery_name URL variable.
im still having trouble with this i would like to have only one search result at a time after selecting from drop down list can you look at the attached page for help thanks
please post a link where i can see the problem in a browser
