Power Gallery 2
Thread began 10/08/2011 10:45 pm by elgueromero13396227 | Last modified 10/21/2011 2:38 pm by elgueromero13396227 | 2226 views | 10 replies |
elgueromero13396227
Power Gallery 2
I went to install 2 and this is what i got. Any advice would be great, thanks.
emerg_training.php
in the webassist/caching/PG_CachedResize_Image.php file.
change line 14:
$retVal = is_dir($pathname) || @mkdir($pathname, 0777);
$retVal = is_dir($pathname) || @mkdir($pathname, 0755);
and line 360:
mkdir ($cachefolder,0777,true);
mkdir ($cachefolder,0755,true);
elgueromero13396227
I did as you instructed and I see another error. Any advice would be appreciated, thanks.
what is the new error?
elgueromero13396227
gal_training.php
emerg_training.php
make sure that the permissions on the powergallery/images/ folder and all files and folders under it are set to 755
elgueromero13396227
I have done all of the above I do believe. I did a ful install over again and completed all the steps. I'm getting these errors.
emerg_training.php
gal_training.php
thanks
elgueromero13396227
Same problem
Technical Support Ticket # 133972
This is closed but the issue is still there. I can not update the theme, width, color, ect. and then save it to a theme name.
What do you suggest I do?
I have reopened your ticket.
