Page redirect after submit
Thread began 10/07/2011 1:57 am by jvorzimer358609 | Last modified 10/10/2011 3:55 pm by Jason Byrnes | 873 views | 7 replies |
jvorzimer358609
I am putting together a form to get answers to some questions and need to check the score and redirect to one of 2 pages depending upon the score they get.
I'm just starting to wade my way through Data Assist so I'm a little slow with this so far.
so this is a test of some sort?
This is going to take some custom coding to accomplish
you will need to have a database with a table of answers:
answers:
answerID - Primary Key
answerText - varchar
then create a recordset to look up the answers entered and compare them against the answers in the db, using the COUNT function you can return a number of matches.
for example, lets say you have form elements named "answerOne" and "answerTwo". create the recordset using advaced view as:
SELECT COUNT(answerID) as testScore
FROM answers
WHERE answerText = paramAnswerOne AND answerText = paramAnswerTwo
in the Variables section, create the two parameters:
Type: text
Default value: -1
Runtime Value: $_POST['answerOne']
Type: text
Default value: -1
Runtime Value: $_POST['answerTwo']
the you can use an if statement to do the redirect based on the testScore from the recordset
if($row_recordsetName['testScore'] == 2) {
header("Location: page1.php");
} else {
header("Location: page2.php");
jvorzimer358609
Thanks Jason
Actually there are only four questions and they need to answer yes to each one to "pass". It is a "test" of how they personally evaluate their progress in the materials on the site. Once they can answer yes to all the questions their status is upgraded and they get more materials. The redirect is needed so send them to one of two pages to inform them whether they are moving ahead or need to continue at their current level.
Honestly, I have struggled a bit with header calls. If I understand correctly, this code must go above the DOCTYPE declaration so it exists before any HTML is present.
ok, that's a little simpler:
if($_SERVER['REQUEST_METHOD'] == "POST") {
   if((isset(
$_POST['element1']) && $_POST['element1'] == "yes") && (isset($_POST['element2']) && $_POST['element2'] == "yes") && (isset($_POST['element3']) && $_POST['element3'] == "yes") && (isset($_POST['element4']) && $_POST['element4'] == "yes")) {
     } else {
yes, the header code needs to come before any HTML on the page.
jvorzimer358609
OK - I know I am being a bit simple here but I'm still having trouble with this redirect. Once I have this working I can do the DB update for their status. Here is the error msg I am getting:
Warning: Cannot modify header information - headers already sent by (output started at /homepages/46/d366494719/htdocs/myoscript3/php/modules.php:4) in /homepages/46/d366494719/htdocs/myoscript3/php/modules.php on line 30
I have attached a zip of the page with the form.
modules.zip
the error is caused by the blank line at line 3.
see this thread for details on the headers already sent error and how to troubleshoot it:
showthread.php?t=19285
jvorzimer358609
I got rid of the error msg but no matter what input I send with the form the same (modules.php) page comes back up so the redirect isn't taking place for some reason.
I'm still struggling with the whole header call - it's always seemed to be something I have trouble grasping.
Thanks for all the help Jason.
modules.zip
my initial code had a misspelling of "Location.
change:
header("Locaion: modulesPos.php");
} else {
header("Locaion: modulesNeg.php");
header("Location: modulesPos.php");
} else {
header("Location: modulesNeg.php");
