Ecart Store Details in Database issue...
Thread began 10/06/2011 11:12 am by daniel279790 | Last modified 10/07/2011 6:23 am by daniel279790 | 622 views | 2 replies |
daniel279790
Hi There
I've been successfully using the 'Store Cart Details in Database' feature for a couple of years now and it's always worked well.
But now I seem to be having a problem with one of my customers who is saving their cart (to retrieve at a later date) but when they return it hasn't saved their order.
Everyone else seems to be using the feature just fine. I'm now thinking the issue with this particular customer is he's trying to save extremely large shopping carts 600+ items, as when I got him to do a test and only save 2 items it saved just fine! But then when he tried to add a large order again it didn't save and actually deleted the older (2 item test).
Is there a size restriction on saving carts to a database or can anyone think of any other reasons why saving very large carts would make it not save and then their past save in the database disaspear?
I'm using Ecart 4.5.2 in Dreamweaver CS5 and the database is a basic online phpMyAdmin database.
Many Thanks
the way the store order details works is to loop through each line item in the cart and perform an INSERT operation to the MySQL database.
If you have 600 line items in the cart, this will cause the loop to take a little while to complete all 600 inserts.
most likely this is causing the script to exceed the php Max Execution Time. this is a setting in the php.ini that limits the amount of time a php script can run for
you can try adding the following code at line 1 of the page with the store order details behavior on it to increase the max execution time setting to infinity:
<?php set_time_limit(0); ?>
it's also possible that the MySQL server has a limit on the number of INSERTS that can be processed in a certain time period, if that's the case, you will need to contact the host.
ass for overwriting the order, the store order summary behavior sets a session variable that is used as the OrderID if this session is not cleared after the order is stored, it will overwirte the previous order. Most likely when you tested the second time, you did not close the browser window first so the previous order session was still alive.
daniel279790
Once again Jason thanks for your help.
I'll add that code and hopefully it will sort it. :)
