ps4.5 wont save "non taxable" setting
Thread began 10/05/2011 9:11 pm by info385819 | Last modified 10/06/2011 8:12 am by Jason Byrnes | 801 views | 1 replies |
info385819
In admin products, there is a setting that allows the user to make an item " Non Taxable"
This setting will not update or save when the admin chooses it and then attempts to update/save the setting on an existing product. It will always remove the check mark, making the product taxable again. All other settings save properly.
in another thread, I started a support incident for you, I will look into this problem with you at the same time as the other issue.
