Datassist and Spry Tabbed Panels
Thread began 10/05/2011 4:53 pm by Paul | Last modified 10/06/2011 9:56 am by Jason Byrnes | 1097 views | 1 replies |
PaulBeta Tester
I would like to arrange my DA Update page into a 6 tab spry tabbed panel, as the fields on my update page are numerous and are arranged into groups - and this makes for a better user experience than one long page of fields.
Obviously i'm going to run into a 'form-per-tab' situation, of which I assume the the update page will not process.
Can any recommend my best approach to this?
I'm thinking; encapsulating the entire spry in a single form, and have a single update button on the last tab, my simple attempt has failed miserably!
Any ideas?
Thanks, Paul
yes, this is the way to go.
after the wizared creates your update page, it will be easiest to delete the existing form, create a new one, then edit the update record behavior and bind each database column to the new form fields.
Make a copy of the update page first that can be used for reference if you are stuck on something.
Delete the existing form on the update page. to add a new one, go to Insert -> Form -> Form to add the form to the page.
Place your cursor inside the form, then insert the spry tabbed panel
configure the spry tabbed panel with the tabs you would like to have, then start adding form elements to the tabs by going to Insert -> Form -> Text Field
for each form element go to the properties inspector, click the lightning bolt next to init value and select the corresponding column from the WADA recordset .
After the form is created, you will need to edit the Update Record server behavior. for each database column, click the lightning bolt and select the corresponding form element.
