HTML editor link - bug
Thread began 10/05/2011 10:06 am by rob75685 | Last modified 10/05/2011 1:11 pm by Jason Byrnes | 1745 views | 5 replies |
rob75685
hi there
I'm using 3.0.2
If I have a new HTML editor window online, add some copy then add a link, and set the link to be an email it works fine, until I go back and change some of copy and update - it changes the link into an incorrect URL...
Can you help please ?
what is the code for the link in source view before you update?
what is the code for the link in sourrce view after you update?
can you send a copy of your page in a zip archive please.
rob75685
Files and code
Thanks for your help Jason - page attached
Before updating:
<a href="mailto:fiona@missjonespa.com">fiona@missjonespa.com</a>
After updating:
<a href="&quot;&quot;mailto:fiona@missjonespa.com&quot;&quot;">fiona@missjonespa.com</a>
It happens on other pages as well with HTML editor 3.0.2
news_Update.php.zip
that's because there is formatting on the Initial value of the HTMLEditor instance to convert quotes (") to the HTML Entity (&quot;)
to fix the problem, edit the HTML Editor instance, click the lightning bolt next to Initial value and reselect the column from the recordset.
rob75685
Brilliant - thanks Jason
And thanks again for responding so quickly
no worries
