Obscured drop-down css menus
Thread begun 10/05/2011 4:16 am by rob.parkin390637 | Last modified 10/11/2011 7:58 am by rob.parkin390637 | 5859 views | 8 replies |
rob.parkin390637
I have a php site originally created with siteassistpro. The dropdowns from the navigation menu are being obscured by an apDiv Tag. The Div Tag contains a Flash Movie.
I’ve set the z:index of the apDiv to a low number and all of the CSS elements (that is for all those that I could find in menu.css and menu_ie.css) of the CSS Drop-Down Menu to a high number. This seems to have worked for Firefox (where the menus now display correctly) but not for IE, Chrome or Maxthon (where the drop-down parts are still being obscured by the Div Tag).
Is there something else I can change to make the drop down menu elements stay on top ?
please send a link where i can see the problem.
rob.parkin390637
Hi Jason
Link to problem page as requested:
index.php
rob
I must be missing something, I dont see a problem on that page with the menu going bellow the flash movie?
have tested in Fire Fox and safari, what browser are you using?
maybe try clearing the browsers cache?
rob.parkin390637
I always test my pages against a range of browsers and this time I get a strange mix: Internet Explorer 9, Maxthon and Google Chrome all fail to show the full menu drop downs but Opera and Firefox seem to work ok.
In order to ensure that your Flash movie does not display over all other elements on the page, you need to apply the wmode="transparent" parameter to the <embed> reference for the swf file.
e.g.: <embed src="myflashmovie.swf" wmode="transparent">
View the following link for more information: tn_15523.html
you may also run into problems with the apDiv1 element having the position set to absolute.
@import url("CSSMenuWriter/cssmw_home/menu.css");
#apDiv1 {
position:absolute;
height:390px;
z-index:0;
top: 215px;
padding-left: 8px;
When working with the stacking order with z-index in css, you also need to specify a position. the z-index is broken up into layers depending on the postion
The absolute position layer is on top, with the relative position layer bellow it
the menu uses relative positioning, in the menu css at CSSMenuWriter/cssmw_home/menu.css i can see you have tried setting the z-index:
ul#cssmw_home {
cursor: default;
list-style-type: none;
margin: 0 0 0 0;
padding: 0 0 0 0;
z-index: 10000;
but without setting a position, it's not changing which layer it applies to.
try using:
ul#cssmw_home {
cursor: default;
margin: 0 0 0 0;
padding: 0 0 0 0;
z-index: 10000;
position:absolute;
rob.parkin390637
Hi Jason
Thanks for looking into this for me. Sorry to report that neither adding wmode="transparent" to the Flash parameters or changing the position to absolute in the cssmw_home/menu.css file seems to make any difference.
The drop-down menus are visible in Firefox and Opera but obscured by the Flash movie in Maxthon, IE, Chrome and Safari.
did you use the Dreamweaver property inspector to set the WMODE? Or did you manually edit the code for the object parameter?
you need to use the property inspector to set the WMODE property. There is more than one place the change needs to be made, using the property inspector will make sure the change is made in all of the places it needs to be made.
rob.parkin390637
BAD NEWS:
I'm using Dreamweaver CS3 and the property inspector in this version doesn't seem to have anywhere to set these parameters for the Flash movie.
GOOD NEWS:
Having looked at the code there seems to be only 3 places that WMODE could be inserted - so I stuffed it in all three places and behold the menues are now visible in Firefox, Maxthon, Chrome, Sarafi and Opera.
BAD NEWS:
The menus are still being obscured in IE9 ...
I guess 5 out of 6 is reasonable - just a pity the duff one is IE as I've heard that rather a lot of people use this !!
