Can't edit logo image in PS4.5
Thread began 10/04/2011 7:38 pm by lrawlins367093 | Last modified 10/10/2011 4:08 pm by Jason Byrnes | 674 views | 3 replies |
lrawlins367093
When I go to change the default logo on my store I get the following error message:
Error
MDB2 Error: no such database
connect: [Error message: Could not select the database: PASCO/web/] [Native code: 1049] [Native message: Unknown database 'PASCO/web/'] ** mysql(mysql)://root:xxx@localhost:3306/PASCO/web/
Any ideas what I'm missing and how to fix it?
mike.lynch373991
I'm getting this when trying to edit a theme...
Warning: fopen(../../themes/temp_editing/css/configurable.css) [function.fopen]: failed to open stream: No such file or directory in /home/content/l/e/a/leasa44/html/wordpress/store/products/webassist/plugins/styler/styler.php on line 99
Warning: filesize() [function.filesize]: stat failed for ../../themes/temp_editing/css/configurable.css in /home/content/l/e/a/leasa44/html/wordpress/store/products/webassist/plugins/styler/styler.php on line 100
Warning: fread(): supplied argument is not a valid stream resource in /home/content/l/e/a/leasa44/html/wordpress/store/products/webassist/plugins/styler/styler.php on line 100
Warning: fclose(): supplied argument is not a valid stream resource in /home/content/l/e/a/leasa44/html/wordpress/store/products/webassist/plugins/styler/styler.php on line 101
Warning: simplexml_load_file() [function.simplexml-load-file]: I/O warning : failed to load external entity "../../themes/temp_editing/theme_settings.xml" in /home/content/l/e/a/leasa44/html/wordpress/store/products/webassist/plugins/styler/styler.php on line 104
Fatal error: Call to a member function asXML() on a non-object in /home/content/l/e/a/leasa44/html/wordpress/store/products/webassist/plugins/styler/styler.php on line 117
delete the webassist/themes/temp_editing/folder, it will get recreated the next time you try to edit a theme.
