Update Page / Update Menu
Thread began 10/04/2011 11:14 am by info271221 | Last modified 11/01/2011 11:39 am by Jason Byrnes | 759 views | 5 replies |
info271221
My update dynamic menu is not retaining the initially selected item.
versatool_Update.zip
do you mean the gallery select list? is that what you are referring to?
if so:
In design view, click on the select list.
In the property inspector click the dynamic button
click the lightning bolt next to select value equal to.
from the dynamic data bindings, expand the WADAphotogallery recordset and select the GalID binding.
info271221
Update page, update menu dynamic join
I think my problem is that I do not know how to create a dynamic join. The gallery id is in the photogallery table but the gallery title is only in the galtitle table. Therefore I believe I need to select the galid that is in the photogallery table and the galtitle from the galtitle table. This is what I have and it is displaying the selected gallery twice in the menu and the entire list once in the menu and it is NOT selecting the initially selected as initially selected, it is selecting the 1st item in the GalTitle table.
<select name="GalID" id="GalID">
<option value="<?php echo(str_replace('"', '&quot;', $row_WADAphotogallery['GalID'])); ?>" selected="selected"><?php echo(str_replace('"', '&quot;', $row_WADADynListphotogaltitle['GalTitle'])); ?></option>
<?php do { ?>
<option value="<?php echo $row_rsGalleriesList['GalID']; ?>"><?php echo $row_rsGalleriesList['GalTitle']; ?></option>
<?php } while ($row_rsGalleriesList = mysql_fetch_assoc($rsGalleriesList)); ?>
</select>
can you send a copy of your insert page? This may help me understand the problem a bit better.
info271221
Here is a fresh insert and the update. I have the pages in the powercms template.
versatool_InsertUpdate.zip
Ok, on the update page the code for the galleries list is:
              <option value="<?php echo(str_replace('"''&quot;'$row_WADAphotogallery['GalID'])); ?>" selected="selected"><?php echo(str_replace('"''&quot;'$row_WADADynListphotogaltitle['GalTitle'])); ?></option>
              <?php do { ?>
              <?php } while ($row_rsGalleriesList mysql_fetch_assoc($rsGalleriesList)); ?>
            </select>
delete the first option:
then in design view, select the gallery list, in the property inspector, click the Dynamic button.
Next to the "Select Value Equal To Option, click the lightning bolt and select, expand the WADAphotogallery recordset and select the GalID column.
