Error in SA 2
When I try to apply security access to pages, DW gives me the following error:
Error*in*Site*Tools*Progress*Panel*initializeUI:
TypeError: wa.user_interface.has no proprieties
Delete the Dreamweaver Cache file from the users configuration folder:
Deleting the cache is the first thing I tried. I do it on every DW error now. It usually does the trick but not this time.
the error "initializeUI" always happens as a result of a bad cache file.
I have seen suborn cases where you need to restart the computer, then delete the cache file again, but i have yet to see a cache where deleting the cache file did not correct the initializeUI error.
try rebooting, then deleting the cache again, If that does not work, I will start an incident to look into the error.
Gave it a go and I still get the same error. Do you think an uninstall/re-install might help?
yes worth a try
