Price not showing up at all
Thread began 9/30/2011 10:51 am by movygirl244169 | Last modified 10/28/2011 9:45 am by Jason Byrnes | 2824 views | 11 replies |
movygirl244169
I'm trying to use eCart and the price & picture is not showing up as 0.00. And whenever I try to add a different size it shows up as the first size on the size list. I have sent some screen shots along with the files. I need to get this finished up and keep running into problems!
In the eCart object, make sure to set the Size column to be unique.
Please send a copy of the add to cart page and the cart display page in a zip archive.
movygirl244169
I fixed the cart objects. And now it doesn't do anything!
Archive.zip
looking at the code on your page, there are multiplle form tags around each element, there is a form around the submit button:
<form name="eCart1_1_ATC_<?php echo $row_WADAProducts["ProductID"]; ?>" method="POST"  action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""?>" valigh="bottom">
                                <input type="hidden" name="eCart1_1_ID_Add" value="<?php echo $row_WADAProducts["ProductID"]; ?>" ><input type="text" name="eCart1_1_Quantity_Add" value="1" size="4" /><input name="eCart1_1_ATC" type="image" class="eC_ImageButton" value="Add to Cart"  src="../WA_eCart/Images/Desert Spice/Btn2_EN_addtocart.gif" alt="Add to Shopping Cart" border="0" /></form>
a form around the size label:
<form id="sizes" name="Sizes" method="post"  action="">
                              <label for="select"></label>
                          </form>
but no form around the size select list.
this means that when the submit button is pressed, the only thing submitted to the server, is the submit button.
looks like the add to cart button code was edited after it was applied to the page.
movygirl244169
so how do I fix it?
by removing the add to cart button code form the page, then re applying the add to cart button behavior.
movygirl244169
Deleted button but it's still not working. It's now telling me there's an error on line 91. I'm not sure what you want me to delete.
Archive.zip
the error at line 91 is referring to a column in the eCart object named "SKU Number". do not use spaces when naming eCart object columns. Use "SKUNumber" as the column name instead.
movygirl244169
Okay fixed line 91 & 99. but the results page doesn't go to the detail page. I looked at the links. Now I can't get to the detail page so I can test the add to card button.
Archive.zip
