Connection problems, MySQL error #200
Thread began 9/30/2011 8:34 am by smorin315817 | Last modified 9/30/2011 11:45 am by Jason Byrnes | 11001 views | 3 replies |
smorin315817
When I try to use the DataAssist wizard to create my connection to my MySQL database, I get an error that states the following:
MySQL Error# 2000
mysqlnd cannot connect to MySQL 4.1 using the old insecure authentication. Please use an administration tool to reset your password with the command SET PASSWORD = PASSWORD('your_exsisting_password'). This will store a new, and more secure, hash value in mysql.user. If this user is used in other scripts executed by PHP 5.2 or earlier you might need to remove the old-passwords flag from your my.cnf file.
I tried to figure out where this .cnf file is, but can't locate it. What do I need to do to get this operational? Thank you for any help!
are you using a Local testing server or a remote testing server.
You should update the MySQL Server version to the latest version, if it is a remote testing server, then you will need to ask your host to do this.
smorin315817
I just installed Xampp so it is a local server, where can I change that setting?
see this thread on stack overflow for details on fixing this:
cannot-connect-to-mysql-4-1-using-old-authentication
