Show if redirected to login page
Thread began 9/30/2011 3:49 am by John Langer | Last modified 9/30/2011 7:49 am by John Langer | 1117 views | 2 replies |
John LangerBeta Tester
So far I have set up a login page for a specific area of the site based on an access rule. I've also set it all up so that if someone returns to a page without logging in then they are redirected to the login page.
That's all working with no problems.
What I want to do is add a bit of text "You have to be logged in to view this page". Above the login form. But I only want it to show if they have got there from a redirect. I've tried this but it doesn't work and I'm at a bit of a loss.
Any help would be appreciated.
if ("$redirectURL== "TRUE") {  // WebAssist Show If
             <p>You need to be logged in to view this page.</p>
// ("$redirectURL" == "TRUE")
try using this code instead:
<?php if (isset($_GET['accesscheck']) && $_GET['accesscheck'] != "") { ?>
<?php ?>
Thank you Jason, that works a treat. :)
